How to have the same Remesh result with a different Position
   1303   2   1
Hello
For a cloth set up I need to have the same remesh (via Remesh SOP node) result of an object on each shot. The object to remesh is the same in all shots, but is Position change. I can not dive in the Remesh node but it seems that while translating an object, is remesh result change.
What I want to achieve is to have the same remesh result for each object base position.
My ideas was to use a rest pose, or find a VEX function that does the same as the Remesh node but I can't figure it out.
Thank you for ur time
you can plug rest version of your geo into second input of the Remesh, it will be used as reference
Edited by tamte - May 24, 2022 12:23:48
Thanks a lot ! It also works with a remesh and a blendshape
