Hi
I can render polygons as subdivision surfaces with Renderman 24.4 in the OBJ context without any problems. In the stage context, Solaris, I have not been able to render polygons as subdivision surfaces with Renderman. Karma works fine.
I am learning Renderman and would appreciate any suggestions.
Mark
Renderman subdivision issue in Solaris
2556 2 0-
- markfel
- 2 posts
- markfel
- 2 posts
- shubhra666
- 2 posts
Use a sop modify and add unpack usd to polygon. click on the same node and follow this instruction given below to get render properties added to your model.
https://renderman.pixar.com/resources/RenderMan_20/rfhSubdivision.html [renderman.pixar.com]
Post this come out to the stage context and select the sop modify node- on the parameter pane go to the import from sop tab - geometry handling- switch on the treat polygon as subdivision surface.
done
Check the attached file and image
done
