Motion Blur & Alpha of Explosion Render in Mantra
   2405   6   0
Hi Guys!
i'm having trouble on rendering my Explosion.
  When I render the explosion with the ground they behave normally
but when I render the explosion alone, it becomes like this
I don't know if it's because of the open blur that affects the edges and becomes a bit transparent or something.
Any idea on how to solve it?
Edited by GU - May 30, 2022 02:47:35
Is your motion blure on?
sajadalavi
Yes, i need to turn on motion blur at work
Edited by GU - May 30, 2022 02:46:44
Is it still the same if you turn off motionblur?
If everything works out without motionblure, you have two options:
1. Render without motionblure and in the composite step, add motionblure.
2. With volume wrangle, multiply the vel vector by a number less than 1, for example 0.2, and control this motionblure.
sajadalavi
I have rendered one without motion blur, it becomes like this,looks correct
Edited by GU - May 30, 2022 08:30:27
sajadalavi
Ok, i think i will try it again, thank you for your valuable comments!
