Husk.exe CPU priority
   1946   2   1
Is there any way to tell husk to launch in low or below-normal CPU priority mode? I see a -threads switch, but nothing about priority. Am I missing it?
Thanks,
Brad T.
Windows does offer the START command where you can specify an EXEs priority. Try typing "start /?" at a command prompt.
Edited by Enivob - June 1, 2022 12:05:15
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Thanks! I hadn't thought of that. Unfortunately, the start command launches husk in a new command shell. There is a switch that's supposed to prevent that, but it doesn't seem to work. That causes problems for hqueue.
