Multiple length dictionary array attributes
   1496   3   0
Hi, I'm trying to make an array of dictionary attributes. This seems successful in vops, but not in Python where I need it for the complexity.
I'm wondering if my code is incorrect, or if it's actually a bug. Thanks!
Edited by BitreelTD - June 9, 2022 14:49:19
variable_length_dict_arrays_python.hiplc (194.2 KB)
I can't exactly tell you why this happens, but if you dont use the dict_array_attrib variable for setting the attrib value, but use the attributes name instead, it works.
I updated your file.
Edited by gorrod - June 10, 2022 05:34:43
variable_length_dict_arrays_python.hipnc (199.1 KB)
Awesome thanks for the find!
Also you may try the latest build
19.0.645
Setting dictionary array attributes in Python should now work.
Fri. June 10, 2022
