bad parameter error?
   1251   2   0
hi, I'm still relatively new to Houdini and I'm trying to control the uniform scale with both min and max values and using the for-loop to do it for multiple lines. when using this expression it seems not to work and comes up with a bad parameter error.
What are 'min' and 'max' referring to? The transform sop doesn't have any such parameters.
Edit parameters interface - add this two parameters
