Vellum pin constraints problem
   2440   1   0
Hi everyone,
I just started using houdini a couple months ago, but right now i'm having some trouble with a vellum simulation;
It's kinda basic, i'm trying to make a cape slighlty move in the wind, but only a small part of it.
I pinned the points i wanted to stay fixed, in the "pin to animation" section of the vellum cloth, but the effects is kinda harsh, i wanted a more subtle effect.
I tried to play around with the stretch stiffness but to no avail. Is there something i'm missing? or is there a better workflow for this simulation?
Thank you all
Screen Shot 2022-07-19 at 17.02.32.png (1.3 MB)
next to the stiffness slider you can choose scale By Attribute instead of No scaling
then you can use 0-1 attribute to control stiffness of your pins to create smooth falloff if needed
Edited by tamte - July 20, 2022 17:20:52
