19.5 Karma Render Resolution
   2993   3   1
Just testing 19.5 Indie. The Karma Resolution settings are not overriding the Camera Settings.
I thought that the Karma Render Resolution used to override the Camera Resolution.
Is this a bug or am I having brain fart?
There's a bug in the Karma ROP.
If you render from stage with usdrender it should be fine.
You can just type "Karma", so you'll be able to set the Resolution using Karma Render Settings
https://www.youtube.com/watch?v=AeS9kCKXkoU&ab_channel=Houdini [www.youtube.com]
copy the Karma resolution parameter to rop_usdrender node inside karma
