vellum solver dop internal value error?
   1236   2   0
A very simple setup. The stiffness in the solver should always be 1.00 per the expressions. Somehow the mop-falloff still has an effect over the bend stiffness.
What did I think wrong?
Please explain.
I am on MacOS ARM 19.5.330.
Edited by sda502 - Aug. 6, 2022 10:31:31
Screen Shot 2022-08-06 at 22.19.19.png (1.7 MB)
11.hip (647.0 KB)
It looks like order of operation, right? The code fetches the value for stiffness, which is 8, multiplies it by the fall off, let say it 0.5 on this frame. That produces a 4 result, which the max function evaluates as larger than 1. The 4 is stored in the stiffness field and gets multiplied by 0.01.
Try resetting the 0.01 to 1.0, and multiply the value of stiffness by 0.01.
stiffness = max(a*(stiffness*0.01),1);
Another way to approach this might be with a fit if you want to specify a specific range for the mops_falloff.
stiffness = fit01(a,4,8);
Edited by Enivob - Aug. 7, 2022 10:34:22
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Now I realised that I was misled to think the code fetched the value for stiffness premultiplied by the order of magnitude, which equals 0.008, also the stiffness value resulting from the vex code was the final stiffness value the machine reads for simulation.
Thank you so much, Enivob.
Edited by sda502 - Aug. 7, 2022 11:40:03
