high resolution vdb collision breaks vellum
   2061   3   1
I came across either a problem or a bug. Hip file included. If you use an sdf as a collision for vellum, at some point higher resolutions break and the bounding of the vdb acts as the collision instead of the correct shape. Check out my video/photo. On the right the only difference is the vdb is higher resolution. Am I doing something wrong? I am using an sdf because the shot (this is a test scene) I am working on the collision has changing topology which vellum doesn't like. The problem is I need by vdb high res to capture all the geometry, but then it only works at low resolutions. What is happening here?
Edited by evanrudefx - Aug. 21, 2022 18:27:15
test_v001.hiplc (504.0 KB)
Thanks,
Evan
no clue what causes this but someone pointed out to me that increasing the half band voxels to a higher value it eventually works for some reason
Thanks,
Evan
just try toggling off the parameter:/obj/setup/dopnet1/vellumsolver1/gascollisiondetect1/"use pscale for SDF"
Edited by Benyee - Aug. 22, 2022 03:09:18
it worked if I did that, but the gascollisiondetect2 had to be set that too. that seems to be another work around
Thanks,
Evan
