Simple syntax help
   1571   2   0
I have created for each loop for every grid object on my scene. And I want to put a different texture map for everyone one of them. So on a null node I created 4 file-image-string box from editing parameter interface. And their names are HeightFile1, HeightFile2, HeighFile3, HeightFile4. And I converted iteration integer to a string from for each loop metadata with the code bellow.
i@iterationPlusOne = detail(1,"iteration",0) + 1;
s@stringedIteration = itoa(@iterationPlusOne);
So this is the part that I couldn't solve for 3-4 hours. I want to read stringedIteration attribute from details and put it next to the ../TileControls/HeightFile. So For every iteration it will be TileControls/HeightFile1 2 3 4.
This is the syntax. Can you please help. Thank you so much.
chs("../TileControls/HeightFile" + detail(0,stringedIteration,0))
Screen Shot 2022-08-30 at 05.01.08 (0-00-00-00).png (1.7 MB)
You need to use the details expression:
details(0,stringedIteration)
animatrix_
Thank you so much. You saved me a lot of time. I thought detail can read any attribute but for strings I didn't know I had to use details
Edited by cinemator - Aug. 30, 2022 10:17:24
