Houdini
2024 2 1-
- johnlahu74
- 6 posts
Hi i'm trying to use some mask created with heightfield erode to generate some terrain textures, when i import "sediment" using user_data_rgb node inside arnold shader network i cannot see the mask. Can someone give some suggestion why this is happening? the sediment mask is successfully created since i can also see it in the attribute vop and spreadsheet geometry. Thanks
Edited by johnlahu74 - Aug. 31, 2022 07:29:44
- jsmack
- 8186 posts
- johnlahu74
- 6 posts
