Adding additional NURBS curves to a NURBS surface
1495 2 0-
- julia923
- 1 posts
I'm new to Houdini and have an assignment that allows only the use of NURBs. I have an existing NURBs surface which has been previously skinned and points have since been edited using the resulting surface. I'm wondering if there's a way to extract my edited curves from this surface so as to skin them with a new curve (see picture)? So far I've tried converting the object and using carve to extract the curves without much luck- I'm a bit stumped. Any help would be appreciated, thanks!
- Benyee
- 64 posts
- tamte
- 9417 posts
julia923you should be able to use Carve SOP in Extract mode to extract NURBS curve(s) out of NURBS surface in U or V direction, what exactly was the issue you were running into?
Edited by tamte - Sept. 14, 2022 00:07:04
