convert images folder to .rat files?
3377 4 1-
- Piledriver
- 99 posts
- freshbaked
- 153 posts
There's probably a way to do this in directly in command line but I'm not good with the syntax so I wrote a Python script to do it for me (I'm also not good with Python).
You can run this directly from Houdini from the Python Source Editor and it should find the imaketx executable.
Or you can change the cmd variable to point directly to a different .exe like maketx from Arnold or txmake from Pixar and fiddle with the command arguments.
import os import subprocess folder = "<path_to_folder_with_your_textures>" out_ext = ".rat" # the output file extension in_ext = ".exr" # the extension of the files to convert cmd = "imaketx" # only convert files with in_ext extension files = (file for file in os.listdir(folder) if os.path.isfile(os.path.join(folder, file)) and in_ext in file) for i in files: name, ext = os.path.splitext(i) infile = folder + i outfile = folder + name + out_ext command = "{} -v -m ocio --format RAT {} {}".format(cmd, infile, outfile) output = subprocess.run(command, capture_output=True) print(output)
Edited by freshbaked - Sept. 8, 2022 18:54:35
- jsmack
- 8184 posts
Piledriver
Hi how i can convert all images file inside a folder to a mipmap files for karma? maybe with pdg its possible?
yes, it's a fairly simple pdg setup. The generic generator can be used to run a command line program and the file pattern node can be used to glob for input files. It can be a little tricky to get the in file out file set up to work, but when you do pdg wil automatically multi thread the convert process per file.
- freshbaked
- 153 posts
Hey sweet! I don't use pdg much so I had no idea about the generic generator.
Just a file pattern node and a generic generator with this command:
Worked like a charm and way faster than my lame python script.
imaketx -v -m ocio --format RAT `@directory`/`@filename``@extension` `@directory`/`@filename`.rat
Edited by freshbaked - Sept. 8, 2022 21:06:26
- Piledriver
- 99 posts
