Pushing Points Along Curve
1536 2 0-
- VGriffith
- 134 posts
- animatrix_
- 5129 posts
You can compute the tangent using the Resample SOP without resampling or the Orientation Along Curve SOP and then use this VEX code in a Point Wrangle:
@P += v@tangentu * ch("amount");
- VGriffith
- 134 posts
Gotcha! I totally did that with the Orientation Along Curve SOP just out of order - In my original case I was trying to do this after the Assemble node with packed primitives and using a @P = point(1, "tangentu", @ptnum); rather than right after the resample node! Totally works! Thank you so much!
Edited by VGriffith - Sept. 14, 2022 16:51:36
