I'm sure many here will be familiar with Adobe After Effects and it's graph editor. That features two modes of operation: a standard function graph and a speed graph. The latter being very useful for retiming and fine tuning animation.
I can see that Houdini has a 'Labs Simple Retime' node - but that is SOP level only.
Is there a speed graph / retime functionality available in any form at OBJ level?
'Speed graph' for object level animation?
2709 6 1-
- Mike_A
- 396 posts
- Enivob
- 2659 posts
Press the V-KEY while hovering over an animated parameter in the properties panel. Just like After Effects, there is only one keyframe, the "speed" is the interpolation through the values. I recommend untying all your handles and adjusting the tangents by hand.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- tamte
- 9579 posts
You an use chops or motionfx to retime animated parameters and object transforms
Depending on your needs it can get a bit messy
I prefer keeping most thing at SOP level, so that potentially only cameras/lights need to be retimed at object level
But Solaris or USD does probably make it easier to retime everything at once
Edited by tamte - Sept. 19, 2022 17:24:11
- Mike_A
- 396 posts
I understand how to see the animation editor and function graph - but that's not what I'm seeking.
Consider a simple two keyframe position animation: a sphere is moving through space. Each keyframe position is an arbitrary location not aligned to any otho axis. The animation editor now has three different and independent curves for X, Y and Z translation. I want to control my objects speed along that path - without disturbing the path itself. That requires a speed graph. If you look at the graph in the SOP level node: 'Labs Simple Retime', you'll see what I'm after - but at the OBJ level.
Edited by Mike_A - Sept. 19, 2022 17:35:45
- Mike_A
- 396 posts
- Mike_A
- 396 posts
- tamte
- 9579 posts
