output xform attribute from topotransfer?
   1337   1   0
Hi! I needed to properly align one object to another so I used a combination of matchsize and topotransfer to do this. Matchsize to get the overall position and topotransfer to do a rigid align, that will get me the proper rotation. Not the fastest solution but the only solution I could figure out. The thing is that my object has animated deformation baked into the object. Topotransfer only does the rigid alignment for one frame. So I need to copy this rigid alignment to all of my frames. However I dont see an option to export an xform attribute. I dont want to recalculate the rigid alignment perframe as that would take a long time, and possibly change from frame to frame. Anybody have any ideas? thanks!
Edited by tarincamarena - Sept. 28, 2022 17:44:47
You can use Extract Transform SOP to get rigid transform delta between the geo at the frame you aligned stuff to and current frame for example
Edited by tamte - Sept. 28, 2022 21:27:16
