'NoneType' object has no attribute 'geometry'
   3575   1   0
I'm just starting learning Python in Houdini and trying the python scripts in document to get the geometry of a node, it looks simple and straightforward but I got the error saying ‘Node’ object has no attribute ‘geometry’. Please see the output from the Python Shell window:
Error running callback:
  File "labs::Sop/attribute_value_replace/btnInitializeValues", line 1, in <module>
  File "labs::Sop/attribute_value_replace, PythonModule", line 7, in SetParmValues
AttributeError: 'NoneType' object has no attribute 'geometry'
What I'm I doing wrong here, and how can I fix it?
Some nodes don't have geometry, such as the NULL. You must be accessing a node with no geometry or the portion of the node that has no geometry. Can't really tell without seeing the code.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
