SOP group inside a POP network
   2516   6   0
Hey guys.
I made a primitve group in SOPs and in a pop network I want to apply drag only to the particles inside that group. How can I do that?
Thanks.
pop nodes have a group parameter that you can use for your group sop.
That doesn't work. I tried but it shows only "stream_source_first_input"
yes, it does.
You can always use pop groups or streams as well
Edited by sepu - Sept. 30, 2022 18:39:15
ok I see that your group is piped in the first input of the popnet. What if it's piped in the second input?
Then fetch the attrib from a pop wrangle and make sure to change the inputs to "second content geo..." You can either create a grp or an i@myattr and use the group in the pop nodes or vex expressions.
Also, why do you need the grp in the second input?
Edited by sepu - Sept. 30, 2022 19:36:03
I was just testing but you’re right. I group transferred the group to the first input and worked fine. Thx
