Currently trying to choose a range of groups, or for an example:
I have groups rocks01-Red, rocks02-Red, rocks03-Red, rocks05-Red, rocks06-Red.
I only want to grab groups rocks02 to 05.
I know I can use {rocks* ^rocks01-Red} to exclude one group from the selection. But how do I select a range of groups?
I.e {rocks(02-05)}
The Houdini page on group syntax if helpful but misses out on this info or I've completely missing something.
Cheers.
Selecting a range of groups by their number (not value)?
1496 2 0-
- Ollie_Beca
- 5 posts
- tamte
- 9380 posts
Ollie_Becathat's not a valid group name, how did you create those groups?
but let's say your groups are named rocks0?_Red
then you can do something like
rocks0[2345]_Red, so not exactly range, but could be useful for short singledigit ranges
Edited by tamte - Oct. 6, 2022 00:22:00
- Ollie_Beca
- 5 posts
tamteOllie_Becathat's not a valid group name, how did you create those groups?
then you can do something likerocks0[2345]_Red, so not exactly range, but could be useful for short singledigit ranges
It was more just for example purpose. The actual group names I'm trying to deal with are generally like: Test_SE_Bridge_Deck_and_Barriers_Type1_SE_Bridge_Deck_and_Barriers__7935200_ and there's a LOT of them. So the problem I'm having is whenever I use
*[Type10,Type12,Type05,Type08,Type20]*I also get everything that has those numbers in the end number tag. And using Test_SE_Bridge_Deck_and_Barriers_Type[25 30 31 28 27 26 32 24 29]I just select points 1-12 for some reason?Am I just screwed by those number tags or should I start looking at VEX solutions. This is going to be a problem for most of the geometry given to me.
Thanks for the help!
Edited by Ollie_Beca - Oct. 6, 2022 00:52:39
