Doing a bit of vex learning, goal is to make a simple version of the Line SOP in vex. Nothing fancy just create a polyline with arbitrary step size and point number in any axis. How would you make this code better?
//add points
vector dopoints = @P+chv("gaps");
int pnum = chi("pnum");
for (int i = 0; i < pnum; i++)
addpoint(0, set(dopoints*i));
//add prim and do vertexes
int prim0 = addprim(0,"polyline");
for (int i=0; i<pnum; i++)
addvertex(0,prim0,i);
Simple Line sop in VEX - show me a better way to write it
2984 8 1-
- RT_SD
- 38 posts
- animatrix_
- 5189 posts
Here is one way to implement Line SOP in VEX using a Detail Wrangle:
Set it to 64-bit precision if you want more precise results.
However for max performance, I would pre-generate the points using a Point Generate SOP, and create the primitive after VEX using an Add SOP.
vector origin = chv("origin"); vector dir = normalize ( chv("direction") ); float curvelen = ch("length"); int ptcount = chi("points"); float u = 1.0 / ( ptcount - 1 ); int pts [ ] = { }; for ( int i = 0; i < ptcount; ++i ) { vector p = set ( curvelen * i * u, 0, 0 ); matrix3 m = dihedral ( { 1, 0, 0 }, dir ); p = p * m + origin; int pt = addpoint ( 0, p ); append ( pts, pt ); } addprim ( 0, "polyline", pts );
Edited by animatrix_ - Oct. 31, 2022 08:30:29
- RT_SD
- 38 posts
- animatrix_
- 5189 posts
If you pass points directly to the addprim function, Houdini creates the vertices for you automatically.
- RT_SD
- 38 posts
animatrix_
How would I implement that in the code I wrote - I just want to strip it down to the basics with just number of points and a distance between them so I can understand the grammar better. Looks like you have to create an empty array of points first then do the loop?
- animatrix_
- 5189 posts
RT_SDanimatrix_
Yes using my approach you have to gather all the points inside an array to pass to addprim.
- RT_SD
- 38 posts
animatrix_OK I edited yours to get this... so append is what's putting the added points into the empty array correct? Or is there another way to do it?RT_SDanimatrix_
int ptcount = chi("points"); float u = chf("length"); int pts [ ] = { }; for ( int i = 0; i < ptcount; ++i ) { vector p = set (i * u, 0, 0 ); int pt = addpoint ( 0, p ); append ( pts, pt ); } addprim ( 0, "polyline", pts );
- animatrix_
- 5189 posts
RT_SDanimatrix_OK I edited yours to get this... so append is what's putting the added points into the empty array correct? Or is there another way to do it?RT_SDanimatrix_
Yes using my approach you have to gather all the points inside an array to pass to addprim.int ptcount = chi("points"); float u = chf("length"); int pts [ ] = { }; for ( int i = 0; i < ptcount; ++i ) { vector p = set (i * u, 0, 0 ); int pt = addpoint ( 0, p ); append ( pts, pt ); } addprim ( 0, "polyline", pts );
Yes. There is also a push function, but append is newer:
https://www.sidefx.com/docs/houdini/vex/functions/push.html [www.sidefx.com]
- RT_SD
- 38 posts
animatrix_
Thanks, I could not find any of this info in the docs or tutorials, it's really helped.
