OpenColorIO as Viewport default
   1638   2   1
Hey everybody,
Does anybody know a way to set the color correction for the viewport to OpenColorIo as default?
Cheers
CYTE
CYTE
Hey everybody,
Cheers
CYTE
You need to provide an OCIO config and export the OCIO environment variable into the environment that houdini inherits.
You could use the config that ships with Houdini. for example:
OCIO="$HH/ocio/config-aces-cg.ocio"
Thank You jsmack!
That solved my issue perfectly!
