Hi All,
I've been testing the latest KarmaXPU update on my M1 specced machine. Currently it doesn't look like XPU is utilising GPU cores on the M1 machines? is this correct?
When I go to render I still see Embree CPU 100%. Shouldn't this be 0% if GPU is being used?
KarmaXPU only using CPU - Apple Silicon
2308 3 0-
- Tomotron89
- 10 posts
- jsmack
- 8177 posts
- Tomotron89
- 10 posts
- jsmack
- 8177 posts
Tomotron89
Ok I was confused switching between CPU and XPU. XPU seemed faster than CPU so I thought it was using GPU.
They're two different renderers. Karma CPU uses VEX-based shaders that are someone backwards compatible with Mantra. Karma XPU is a new renderer that only supports MaterialX based shaders and USD preview surface shaders and a few others that are specific to XPU. XPU uses CPU and GPU if available.
