Vellum Pressure unknown forces
   3114   4   1
Hi, I'm trying to control vellum pressure constraint, I want to have an object stay in place and just inflate. However, the object just starts to spin; I've tried smooth iterations as the docs said but that hasn't helped. Any way how I can just have the object stay in place and inflate without unbalanced spinning without pinning it? (file attached)
balloon_type_effect_forum.hiplc (698.6 KB)
hou.f*ckatdskmaya().forever()
Is it better to start with a puffed-up version of the model so vellum can store volume for pressure solve, then deflate and reinflate for the effect you want, or is there a workflow to start with a flat model and use pressure scale and rest length to inflate model and have good volume?
You could try increasing the mass of your cloth together with Velocity Damping on the Solver/Forces Tab could help counteract the spinning.
The easiest would be to just make some really soft pins with high mass value:
Edited by Yader - Nov. 26, 2022 05:25:51
balloon_type_effect_forum_yader.hiplc (703.1 KB)
https://behance.net/derya [behance.net]
Yader
Thanks @yader, this was helpful and gave me a few ideas to play with.
I was doing some cushions with vellum and found the same problem.
Took me a while to realize that THE SIZE OF THE MESH was influencing this.
I was doing regular size cushions with 0.5x0.5m, and then I just used a grid 10x10m and everything stayed in place.
