Hide static object in dopnet from rendering
   2733   4   0
I have a simple setup with Vellum grain cube and sphere in the middle of it. When I play the simulation, the grains get pushed by the sphere and fly away as expected.
I am using Dopnet and I import the sphere using StaticObject and grain using VellumObject
However, when rendering the scene using Mantra to MPlay the big sphere is still visible in the render.
Can anybody please tell me how exactly can I stop this from happening?
I have searched the internet for a few hours to no avail.
I have included a .hip file so you can take a look.
Thanks a lot.
HideTheSphereStaticObject.hipnc (587.7 KB)
I believe you just turn off the display mode for the geo node of the sphere in obj level. It will be visible in the sim in the dop net but should be invisible in the render and outside the dopnet.
It is a good idea to import the dop objects back into sop level to render. there You can apply materials and You have finer control what You want to render.
Thanks for the reply, hiding the geometry did not work.
Can you please look into the attached file?
I have already tried removing the display flag from the "HideThis" sphere as shown on image.
The dopnet is in the "box1" geometry.
Screenshot 2022-12-10 at 0.34.15.png (115.0 KB)
I have found the solution.
The key is to type vel* into the object field of dopnet here is pdf guide and a sample file.
Edited by raketoplan - Dec. 11, 2022 14:46:12
hide-static-object.pdf (1.9 MB)
TheSphereStaticObjectHidden.hipnc (565.8 KB)
