Materialx displacement shader error
   3371   4   0
what's going on?The displacement shader is working or not?
Do you have anything plugged into the Displacement shader? The warning is telling you that the shader isn't doing anything, so it's being skipped for efficiency purposes. A Karma MtlX Subnet automatically creates a MtlX Displacement node and connects it to displacement_output. If you leave it in the network but don't actually use it, then you'll get this warning.
BryanRay
Can we disable this warning?It's kind annoying.
I don't think there's a way to do that, no. Like most warnings, its purpose is to alert you that there's something wonky. If it's annoying you, then I think the right move would be to fix the shaders, not to disable the warning.
BryanRay
ok.And what about using the mtlx standard surface as default?In most cases,people create the mtlx subnet,dive into,delete the mtlxsurface,oh...
