I need some help on creating a pyton script (shelf tool quick action/button) to rename selected objects based on hip file name and some variations inside the geo container objects. Would be great if someone can help on this.
I added the hip file with the use case.
Tks
Python script to rename selected objects (OBJ level)
1589 3 0-
- rrrlaralasar
- 4 posts
- Enivob
- 2658 posts
There are limits to the character which can appear in a node name, also all node names must be unique. It's not a good idea to name nodes like files, you're bound to end up with mangled names due to automatic character replacement.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- rrrlaralasar
- 4 posts
EnivobYes - I know, but for this specific use case it will help. Also - the nodes in the geo container have unique name. I just want to append the hip file name to it. Can you help in this case? tks
- Enivob
- 2658 posts
You should google around. I quickly found this example. Which shows how to iterate over a selection and obtain hip file name.
https://www.sites.google.com/view/kishenpj/python/python [www.sites.google.com]
