Project still cooks when "Load From Disk" is Enabled
   1932   2   1
On my file cache node I have a file cached and stored on disk. From my understanding the nodes above the file cache shouldn't have to cook again if "Load from Disk" is checked. I feel like this has changed recently, can anyone explain this to me?
The only way I have been able to load from disk properly without cooking anything is disconnecting the filecache from the rest of the node tree.
Vincent Griffith
Edited by VGriffith - Jan. 19, 2023 14:16:43
They can still cook if you have a template flag set on the nodes above the FileCache.
Another way they can still cook is if you have an ObjectMerge fetching from somewhere above your FileCache in another Geometry node, and that node's Display flag is set.
Edited by Enivob - March 6, 2023 08:52:16
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Not sure if this is related, but I've found that if I hit "save to disk" when "Load from disk" is set, it seems to process the nodes above not once, but TWICE... very annoying, and also just a recent thing.
Houdini TD, I focus on tools for procedural asset creation.
www.jaworenko.design
