Exporting points to gltf
   984   0   1
I'm trying to export a bunch of points for rendering in webGL but the gltf rop seems to only export poly primitives and ignores points and polyLines. I've currently hacked around this by creating a poly primitive and adding the same point 3 times in a point wrangle like so:
int prm = addprim(0, 'poly');
addvertex(0, prm, @ptnum);
and then I manually change the primitive mode to 0 in the gltf file (which indicates to render as points):
	"meshes":[
"primitives":[
"mode": 0 //ADD THIS LINE TO FORCE POINT RENDERING
"attributes":{
"_interpolation":2,
"POSITION":1
"indices":0
"name":"wireMesh"
But this all seems super crappy, if there are 3 indices in the same primitive does it re-render the same point 3 times? Also it's just a bad workflow.
Is there a normal way to get Houdini to export a bunch of points to a gltf for gl.POINT rendering?
