UV Layout: avoid rotations? [SOLVED]
   1328   1   0
Hi!
I've got some UVs that are all vertical. I'm using the UV Layout sop to use more of the wasted UV space. I set the Island Rotation Step to No Rotations yet it rotates everything horizontally.
How can I set the UV Layout sop to only move/scale but not rotate?
Edited by olivierth - March 6, 2023 10:50:13
AHHH!
There's a Axis Alignment setting above. I need to set it to None. Now it works!
-Olivier
