Drag duplicate keyfame
   1404   7   2
How does one duplicate a keyframe to another frame by dragging the currently selected keyframe(s), is there a hotkey for that ?
I don't mean "copy keyframe > move to different frame > paste keyframe".
I want to stay on the current frame, and duplicate a keyframe to different frames by dragging them.
I've been searching, but I get the feeling that's not possible in Houdini, or is it ?
Thanks.
I'm sure I've done this before, but I can't figure out how. I wrote it down: middle click + drag + alt + click
But that doesn't work. Any ideas?
+1 For this.
MMB+Alt should copy a keyframe in the timeline.
Thanks. I played around with this and now it works. But different than I expected.
- The current frame indicator has to be at the position from which you want to copy (there could be a keyframe or not)
- First MMB and start to drag, then press ALT.
Right?
@Nedsch, sry I should have made myself clearer.
I meant there should be an option to MMB+Alt drag to copy a keyframe.
There isn't one atm.
Cheers
CYTE
Yes, I noticed that as well the other day.
Seems the only way is to drag a selection box , Copy , LMB drag the box and Paste. And if you don't drag a box first it copies and pastes the animated object
How can it be a basic feature like that is still missing ?
I don't know.
I wish SideFX would dedicate one entire development cycle solely to polishing, adding no new features.
Just cleanup, streamlining, removing UX inconsistencies, and making the Viewport rock solid...
Cheers
CYTE
Thanks for the clarification.
Edited by Nedsch - Nov. 25, 2025 05:50:24
