Exporting to Blender
   1278   1   1
Hi. I am new in Houdini, following the Entagma tutorial [www.youtube.com] with Vincent animating strips falling on a tube.
This method is not working with Blender. I still get the alembic as one element. I can still edit things individually, but I would like, as in the video, to get each strip on a different layer.
Is this possible? I understand Blender limitations are different from Cinema, so it might be a workaround or another way to export.
Thank you
You have to add path or name attribute and export your hierarchy using that attribute. Check out the other Entagma on this topic.
https://entagma.com/exporting-alembics-for-blender-a-few-hacks/ [entagma.com]
Edited by Enivob - March 23, 2023 09:21:33
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
