Performance issues with "merge"
1278 1 0-
- animationalex
- 58 posts
I have run into this issue before, and I ran into it again today. I was wondering if there was a better way to work. I am animating some pieces candy that I am object merging in to a geo node, copying them to points with random animation. Works great, 24fps. I bring in the hero candy which I wrapped with a vellum sim, animate it on its own, works great, 24fps. However, when I use a merge node so I can see them both, the merge complains about not having the same attributes, I get that, but it causes my frame rate to chug at like 6fps and is not use able to animate with. I checked the performance monitor and it pointed to the merge as well. If I take the hero guy out and put him in his own geo node, with show all nodes in my viewport on, so I can see the BG candies and the hero candy at the same time, it works great, 24fps. However now I am split up into two geo nodes. I realize that I can make shortcuts to each geo node, but is there a better way to do it in a single geo node? Is there a "stupid" merge node that doesn't care about attributes or anything and will just show two things together? Apologies about the length, Thank you.
- jsmack
- 8177 posts
