Hi
How come I can create nodes inside an HDA with Python, but I cant delete them later ?
I need to dynamicaly create shaders on the fly, but need my material network not to get overcrowded with nodes after a few iterations. But I could'nt find a way to clean my network at the beggining of each new "cyle".
Any clue on how to workaround this annoying "cannot delete nodes while cooking" error?
THX
DELETE NODE IN PYTHON INSIDE HDA
2990 4 1-
- NAHASSIA
- 125 posts
- tamte
- 9425 posts
NAHASSIAwhy are you trying to delete nodes during cooking?
generally even creating nodes within Python SOP is a bad idea, can you move your code to HDA python module and execute it with a button press or a callback, or does it need to be all the time during cook?
- NAHASSIA
- 125 posts
Thanks tamte
Ok I get that its not a good idea, but.... it is working for createNode...
I'v tryed to call a kill conction on my HDA.module but as I call it from a python inside the hda it gives the same result
I will see if there is some other place where I could trigger this kill fonction. Somesthing like "on recook"
Any way thanks a lot for giving me a direction to where to look.
By the way, I'm not sure to undeerstand why it's a "bad idea"
cheers
cheers
- tamte
- 9425 posts
NAHASSIAyes, because you are still technically calling it from within the Python SOP evaluation which is during cook
NAHASSIAit may of course depend on your exact usecase, I just try to avoid any manipulation of live houdini file from within Python SOP and purely restrict its function to modifying the geometry that's being passed to output, as that's its purpose
modifying the scene outside of this scope can lead to all sorts of issues like triggering additional cooks, or even of the same node leading to infinite recursions or crashing
- NAHASSIA
- 125 posts
