[KineFX] Rig Attribute VOP (Point Mode Not Working)
   1532   1   0
AFAIK, VOP nodes iterate through every element except if specified as detail (which only iterates one)
I'm trying to iterate through every point/joint of my joint chain.
However, for some reason Rig Attribute VOP is stuck at detail despite changing it to point.
Is there a prerequisite to do a point/joint loop in rig attribute VOP?
P.S. In the file below, I try to modify the position of each point but only the first point is being moved.
for_loop_rig_attribute_node.hipnc (215.5 KB)
If you are running over points you have to give the get point transfrom the ptnum attrib for it to work
