Hi, I'm very new to Houdini, and I'm having issues with linking a parameter to a node inside of a nested foreach loop.
I'm trying to set a value in an Attribute Create node so that it offsets an amount (integer) that I set up in an HDA.
I've named this integer parameter test_int.
I thought this could work by referencing the iteration detail from the metadata node, and adding test_int to it.
The parameter expression goes something like this
ch("../test_int") + detail("../foreach_begin1_metadata1", "iteration" , 0)
The problem is, when I try this on a attribute create node that's inside a foreach loop that's also in another foreach loop, it seems to only return the iteration value.
I know that this seems to work with a regular, non-nested foreach loop, but in my case I require it to be inside of another foreach loop.
Does anyone know what I'm doing wrong?
I'm a complete noob, so sorry if I'm not giving enough information to work with, I'm more than happy to respond.
Referencing a integer parameter in a nested foreach loop
2205 4 1-
- nasbee
- 3 posts
- tamte
- 9380 posts
- nasbee
- 3 posts
Hi tamte,
Sorry for the late reply, I didn't notice that my first post was approved.
Anyways, I've been working on the HDA a little bit since my last post but there's been no progression, except that the integer parameter name is "offset_num" instead of "test_int".
Here's the HIP file and the HDA, hopefully it helps
- tamte
- 9380 posts
I looked at your file and there is no offset_num parameter so it will always return 0
there is however offset_num# as a part of multiparm so offset_num0, offset_num1...
so your expression will most likely need to be:
ch("../offset_num" + detail("../foreach_begin1_metadata1", "iteration" , 0)) + detail("../foreach_begin6_metadata1", "iteration" , 0)
- nasbee
- 3 posts
