Karma - Outputting a render log with render stats
   4329   2   0
Hi everyone,
I'm attempting to output a render log to show things like render time and ram usage etc. (and any other nice render stats it can provide) but I've checked all over the "Karma Render Settings" node and have been unable to find anything to do with logging.
Could anyone point me in the right direction?
Thanks so much.
Andrew
Look in the USD Render ROP instead. In the Husk / Statistics tab.
BryanRay
Thank you!
I did see this and could be useful, however the problem is I'm generating a USD file of the scene with the USD ROP node and then using husk command line to render this file.
I was hoping to be able to output a render log file separately using a field on the Karma Render Settings node.
I see there is a "--verbose" command to use with husk, after some digging I figured out how to save this batch script into a separate text file which seems to contain stats such as "Frame Wall Clock Time" (which I presume is the "pixel rendering" time)
All the best.
