AttributeError: 'NoneType' object has no attribute...
   9716   8   1
Hi everybody,
for a couple of weeks I get an error whenever I switch views:
I already updated Python to the newest version but it didn't help.
Is there a way to get rid of this?
This is really annoying...
Günther
Review system requirement. Does your system meet the specifications to run Houdini?
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
I'm working with Houdini for more than 3 years, and this error occurs for a couple of weeks now. And this error only happens when I switch from one view to an other. And the error message doesn't sound like a "system problem", more like a Python problem...
My system:
AMD Ryzen7 5800X 8-Core, 3.8 GHz.
32 GB RAM
nVidia GeForce RTX 3060 Ti, 8 GB
Should be enough, right?
It looks like your system meets the specs. I don't see this on my system, with similar hardware. Are you using any custom toolsets? Are you using the Game drivers or the Studio drivers from nVidia? I'm using studio.
Edited by Enivob - May 22, 2023 09:04:49
I'm using the Game drivers (531.79). Maybe I'll try the studio drivers.
No custom toolsets installed (except Labs).
Am I really the only one on this planet with this error message? Cool...
you may have by mistake registered a callback, although I guess it's an internal conflict.
Does this error message occur sporadically or always when you switch views? Did you select a particular node while doing so?
You can actually check if a callback is registered.
Just enter the following into the Python shell (Windows / Python Shell)
scene_viewer = hou.ui.paneTabOfType(hou.paneTabType.SceneViewer)
viewport = scene_viewer.curViewport()
callbacks = viewport.eventCallbacks()
print(callbacks)
Check if the issue occurs only under a certain state. You can also call the Viewer State Browser (Inspectors / Viewer State Browser), which has its own output - if there is an error, then you know what the problem is.
But if you say you've already reinstalled everything, then that probably won't be the case. I would at least move the user dictionary folder content to another location temporarily; this folder remains the same for all major versions, so the error could still exist there.
HOUDINI_USER_PREF_DIR
C:/Users/*/Documents/houdini19.5
Should be related, if not the same as
Side Effects Support Ticket: #136088
I had this issue only with scene viewers in floating windows. The scene viewers, that were attached to the main window were not affected...
At one point I even got a SIGSEV in je_bitmap_unset
And on another occasion this: in the python shell
  File
"/opt/hfs19.5.605/houdini/python3.7libs/houpythonportion/qt/ViewerOverlay.py",line 57, in closeEvent
    self._scene_viewer.removeEventCallback(self._onViewportEvent)
  File "/opt/hfs19.5.605/houdini/python3.7libs/hou.py", line 77406, in removeEventCallback
    return _hou.SceneViewer_removeEventCallback(self, callback)
hou.ObjectWasDeleted: Attempt to access an object that no longer exists
in Houdini.
Hi vik_lc, GOgraphR!
thanks for your response! It will take a bit to try those things out, but what I can say is...:
The error only happens when I switch views (perspective to left/right etc.). And I always have that window floating. Have to try if it's different when it's docked. Not sure about the node type, because I switch views pretty often, and it happens ALWAYS. Funny side node, uhm, note: There is a button "Ignore future errors", when I press it, it does simply nothing: the next time I switch views the popup comes again...
btw. Enivob: I installed the studio drivers, but it didn't make any difference.
Edited by Sybaris - May 23, 2023 15:20:43
