SOP Solver substeps
1784 4 0-
- Dronson
- 49 posts
- tamte
- 9415 posts
regarding the DOPnet level substeps you can use $SF variable on DOP node parameters or @SimFrame in DOP level wrangle nodes to get absolute substep number
however many solver nodes (POP, Flip, Pyro, Vellum, ...) can introduce additional substeps usually through internal Gas Sub Step which can be nested, so in those cases you may need to accumulate your own counter at particular spot within the tree
- Dronson
- 49 posts
- tamte
- 9415 posts
to get those variable values you can usually use stamp() hscript function and it seems to work for ST , however for some reason SF is giving me 0
the same if I use stamp() function with new variable in ../solver1/d/s/Stamps section based on $SF
but direct reference seems to work
Edited by tamte - May 24, 2023 01:20:25
- Dronson
- 49 posts
