Getting position of object from Dopnet and import to parent
   1127   1   1
Hey everyone, i have problem with LookAt Camera.
I want my direction of Camera LookAt object moving form Dopnet, and parameter LookAt only works with Transform of ObjectNetwork.
I have detached a moving object from dopnet and Objectmerge it into a separate Geometry at objNetworkt.
I want to import that position into the outer parent position (objNetwork), and the Transform parameter of objSubnet will change according to the movement of the detached object from Dopnet.
Can someone help me with that?
Thankyouu!
you could use a match size to set the location of the arrow to the center.
You can then in a seperate branch.
I`ve atached a file.
you can do the same for orientation by using 2 match axis nodes.
PS the transform node is only used to hold the values.
YOu could also use the point("path to node",0,"P",0) ects instead.
untitled.hiplc (142.1 KB)
