Extract ABC transform and match it to skeleton
   1390   2   2
Hello
Please help me to extract the transform from ABC.I have to replace a filmed leg on some footage with a full rigged limb.
The comp team has sent a tracked geometry leg as tibia bone and a knee locator, both in ABC format. We tried to export a fbx but the result was unusable.
So, I have to extract P, rot and orient from ABC and pass it to a root bone of the new leg.
Whatever I tried to get them correct I failed. I tried to get a matrix transform from the centroid imported ABC and copy it to root rig pose...but somehow seams axis are not ok, origin also add an offset, etc. Only crap, not one correct output.
So again, I need the ROOT to follow the 'extract_tansform' location and orientation.
Here he working file [we.tl]
Any help will be appreciated
Thanks in advanced
Forum_ABC_motion_extract.zip (14.8 MB)
there you go, there is a 90deg offset but you can fix that easily
Forum_ABC_motion_extract_fixed.hiplc (819.7 KB)
More code, less clicks.
Jonathan de Blok
Manny thanks. It works like a charm.
What I don't understand is why on my workaround I've got that ROOT bone offset related to captured point.
I used this method many times to stick other geometry to a captured one.
Indeed, was a simply copy to points, as it worked here as well.
This was the reason for 'to_0' rigpose node, to move root node to 0, then copy transform from captured point, without offset.
But isn't work...and still don't know why...
Thanks,
