Context Options Editor - Read Name of Menu Item?
   1474   5   3
Hi, when using the Contex Options Editor, and an Int Menu, is there a way to read the name of the menu item?
For example, I have a menu called shot:
Medium   0
Far      1
Wide     2
I can read the value of the menu easily enough with @shot.
What I also want is to read the name of each item, so when I'm writing a file name, I want it to be $HIP/render/`@shot`.exr, but with the name, not the number.
I have the reverse problem when using a String Menu. With that, I can obviously get the string value, but I also want to get the index of the selected menu item, for the Switch node.
Edited by eikonoklastes - July 20, 2023 06:02:12
In Python you can use hou.contextOptionConfigfor this.
For example, something like this could address your first goal:
import json
menu_items = json.loads(hou.contextOptionConfig('shot'))['menu_items']
shot_idx = int(hou.contextOption('shot'))
shot_name = [item[0] for item in menu_items if int(item[1]) == shot_idx][0]
Edited by robp_sidefx - July 20, 2023 08:02:43
robp_sidefx
import json
shot_idx = hou.contextOption('shot')
shot_name = [item[0] for item in menu if item[1] == shot_idx][0]
Thank you! A fair bit more convoluted than I was hoping for, but it does work.
Thanks again
Side note: In the last line, the name of the array should be menu_items, not menu.
Edited by eikonoklastes - July 20, 2023 06:57:07
Follow up on this:
This does not actually work for an Int Menu. I had set up a String Menu with explicit values of 0, 1, 2, 3 and that's why it worked for me.
For an Int Menu, hou.contextOption returns a float, that needs to be converted to an integer.
Furthermore, this line:
shot_name = [item[0] for item in menu_items if item[1] == shot_idx][0]
produces a list index out of range error.
I replaced it with this, and it seems to work now:
shot_name = menu_items[shot_idx][0]
Here is the updated code:
import json
menu_items = json.loads(hou.contextOptionConfig('still_shot'))['menu_items']
shot_idx = int(hou.contextOption('still_shot'))
return '$HIP/render/still_render_' + shot_name + '.exr'
Sorry, there was a typo in the code initially. I've updated it. Your approach will also work, if your int menu has values 0,1,2,... but may fail if the values are 1,3,2,9,552,...
robp_sidefx
Brilliant, thank you! This does work now for the Int Menu.
