is posible to make cloth interact with its fur?
   1450   2   1
if i attach guide curves into a cloth object but i would like that the guides thickness also be consider in the simulation,
example you have a fur coat that fold in itself in the floor, therefor have thickness there for should not be just flat on the floor is it possible to generate the guides into the same sim loop and add a hair constrain?
i was able to do 2 sims, one for the cloth and a secondary for the guides, but... well the hair won't be considered for the motion of the cloth...
this is a small example.
(thanks, Tamte)
cloth_ball_v1.hip (521.4 KB)
use vellum for both. vellum cloth constraint for coat and vellum hair constraint for fur.
hou.f*ckatdskmaya().forever()
i think i got it, maybe i needed an additional constrain to pin to target and just select the roots so they get glue to the first object they find.
Edited by pelos - Aug. 8, 2023 15:56:46
cloth_ball_v1.hip (611.7 KB)
