Vellum "Pin to target" constraint - points stuck in position
   950   0   1
Hello all!
I need to establish a "Pin to target" constraint in vellum to only be active until a certain point in time.
I actually got it to work following this apporach:
https://www.reddit.com/r/Houdini/comments/15fytvv/i_want_to_edit_vellum_constraint_property_break/ [www.reddit.com]
Now, the problem is: The points of my pin group get fully stuck after the constraints broke.
But they should be following the rest of the bubble, of course, and continue floating around.
HIP attached, any help or advice on a better way to time a "Pin to target" constraint would be much appreciated.
Thank you very much!
complex_vellum_shapes_02.hiplc (1.5 MB)
