Can someone explain the principle behind the DOP motion node
1222 1 0-
- EP nineteenma
- 21 posts
- Enivob
- 2658 posts
Do you mean the performance becomes poor? The motion node doesn't support deforming geometry, only transformation. That's why it's faster. If your collision object's mesh isn't deforming, use motion, if it is deforming, use a FileCache to pre-convert each frame to a VDB for better performance rather than having to convert every frame on-the-fly. That's why the Collision object shelf tool generates the node.
Edited by Enivob - Aug. 28, 2023 14:55:59
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
