Cryptomatte from Karma doesnt work in Nuke nor Fusion Resolv
   2636   2   0
Hello, I ve been started to render using karma and when i export crypto render passes I cant access them in nuke or Fusion
Does anyone know an workaround or happen to know how to fix it ?
I've seen older versions of Nuke won't read the cryptomatte built into the main EXR. Probably similar issue with Fusion.
You can use the cryptomatte LOP and export as a separate pass instead. I believe keeping them as separated files is generally recommended.
With Nuke 14 I've been able to read and use the Cryptomattes baked in the main EXR though.
Edited by Tronotrond - Sept. 6, 2023 16:28:03
Trond Hille - Houdini FXTD at NOV
try checking Enable Legacy EXR Mode on USD Render ROP or Karma ROP
