Using the area of a piece to create name attribute
   2250   6   2
Hi there!
I have a seletion of debris items in various sizes. I would like to give them a sorted name attribute based on their surface area.
Getting the area per piece in a loop is easy enough but how can I use this float value to name the pieces in rising order from small to large? So piece01 would always be the smallest and piece0X will be the largest.
Also the float values for area are huge cumbersome numbers, idealy I would want to remap those into a range matching the number of the pieces.
Here is one way:
Sort by area
Attribute Promote (name) -> from Primitive to Detail -> Array of All
unique_names_array (Detail Wrangle):
string allnames [ ] = detail ( 0, "allnames" );
string names [ ] = { };
foreach ( string name; allnames )
    if ( find ( names, name ) < 0 )
        append ( names, name );
s[]@allnames = names;
assign_unique_indices_per_piece (Primitive Wrangle):
i@index = find ( allnames, @name );
s@newname = sprintf ( "piece%s", i@index );
Thanks a lot for your help!
It's not quite working yet on my end. All indices return a -1 value and the "newname" pieces as well in accordance.
I attached a screenshot and a tiny hip file.
Thanks again!
sort_by_area.hip (143.6 KB)
Oh I see, I forgot to mention the attribute has to be renamed to allnames in Attrib Promote:
Thanks, it's working perfectly now!
Sorry to bring this up again, but how would you go about using the longest edge of the BBOX instead of the area to name the pieces?
Instead of sorting by area, sort by an attribute (e.g. called maxbboxlen) using the VEX snippet:
f@maxbboxlen = max(getbbox_size(0));
