vex that selects polygon size
   2141   8   0
I’m using the following vex to attempt to create a Min max controller with selecting specific polygon sizes and outputting a group from this. But it’s not working and I’m not sure if I’m writing this wrong or not. Thoughts?
float minSize = ch("min_size", 0.1);
float maxSize = ch("max_size", 0.2);
if (@area >= minSize && @area <= maxSize)
setprimgroup(geoself(), "selected_polygons", @primnum, 1);
else
removeprimgroup(geoself(), "selected_polygons", @primnum);
Edited by luidox - Sept. 23, 2023 15:49:59
luidox
else
It works fine if you remove those lines. The removeprimgroup function only takes 2 arguments but I'm not sure why you're using that function anyways...
Also wrangles won't show group highlighting unless you type the group name in the Output Selection Group parameter under the bindings tab!
Edited by freshbaked - Sept. 23, 2023 18:21:54
Unfortunately, the sliders don’t work. Whenever I start moving them from position zero the selection disappears under my group promote. Even without removing the else statement. It still does that I’m not really sure what to do.
Here is one way:
float minarea = ch("min_area");
float maxarea = ch("max_area");
float area = primintrinsic ( 0, "measuredarea", @primnum );
if ( area >= minarea && area <= maxarea )
    i@group_prims = 1;
In this case your using a measure node?
luidox
No. I am just checking the area using the primitive intrinsic attribute called "measuredarea".
luidox
Not sure what else to say other than to just use animatrix_'s more succinct solution.
But to demonstrate that your code works fine here is a screenshot.
Edited by freshbaked - Sept. 24, 2023 12:29:11
Whats your measure settings?
luidox
Default. It's already setup to measure the area of each primitive.
