Printing Node as code in Houdini
   3009   3   1
Hello, I recently stumbled upon a super old forum post describing a way to print a specific node as code in Houdini using the python shell editor.
the line was as follows:
node = hou.node('/obj/geo1/resample1')
print node.asCode()
(I am trying to see the inner workings of the resample node)
However when this is ran it just returns a syntax error:
I am quite new to python and I am unsure on what the issue is / if this even works anymore.
Any help or alternative solutions would be amazing.
Screenshot 2023-10-05 145040.png (10.7 KB)
in python 3.9 you must use print(value) instead of print value
alexeyvanzhula.gumroad.com
I’ve been doing this for years.
However, what you see is not the inner workings. It is just the python definitions for what node it is and parms.
That said, it is very good to know these things if you want to use Python.
However, SideFX has added additional tools when you drag and drop to the shelf. I suggest you 100% to just use that.
Cheers!
Don't use this, because you will get trouble. Use the shelf because it solves those things.
Maybe the code gives some error, but if so, just fix them and it should work. It should then be network_snippets_path maybe.
As I wrote, it just saves the node parms and whatever you can place there. Other data is basically forgotten.
from pathlib import Path
path_user_home = str(Path.home())
network_snippets_path = path_user_home+"/"
def getNodeType(node_path):
    node = hou.node(node_path)
    type = str(node.type().name())
    return type
def saveNodesAsPy():
    for node in hou.selectedNodes():
        if (node == None):
            hou.ui.displayMessage("Please select a node first.")
        else:
            node_path = str(node.path())
            node_name = str(node.name())
            node_type = getNodeType(node_path)
            title = 'Save node as Python - '+node_path
            default_value = node_type+"_"+node_name
            pattern="*.py"
            path_and_filename = hou.ui.selectFile(start_directory=network_snippets_path,pattern=pattern,title=title,default_value=default_value)
            if (path_and_filename == ""):
                hou.ui.displayMessage("Filename is empty. Please try again.")
            else:
                if not path_and_filename.endswith(".py"):
                    path_and_filename += ".py"
                node_file = open(path_and_filename, "w")
                node_file.write(node.asCode(False, True))
                node_file.close()
saveNodesAsPy()
    return type
def loadPyNode():
    '''Import node from py'''
    path_and_filename = hou.ui.selectFile(start_directory=network_snippets_path,pattern="*.py",title="Load node as Python")
    if not (path_and_filename == ""):
        exec(open(path_and_filename).read())
loadPyNode()
Edited by SWest - Oct. 5, 2023 16:20:01
Thanks so much for such an in depth response!
Sorry it took me so long to see this reply.
Much appreciated!
