I don't usually do char. rigging, but I have to fix something. I have a KineFX hand skeleton. A RigPose places the hand in a certain pose. I need to tweak the thumb a bit, but the thumb's joint axes are not properly aligned, they don't point down the thumb bones. I tried using Orient Joints (on just the thumb), Pose Difference (with "Apply Offset"), VEX code (link below), and Rig Match Pose, but I can't get it right. Either the thumb mesh is distorted with re-oriented joints, or the thumb mesh is fine, but the thumb joints are not re-oriented.
VEX solution for orient joints [www.sidefx.com]
KinefX: re-orient some joints. but keep the current pose
3347 4 1-
- element33
- 94 posts
- SWest
- 313 posts
- element33
- 94 posts
SWestI adjusted the pivot axes manually and got it working. Odd, that there are all these SOPs with names that sound like they'd just do the job (Orient Joints. Pose Difference, Rig Match Pose), yet none of them does it in a simple, intuitive manner.
Then do what is needed manually.
Edited by element33 - Oct. 9, 2023 10:08:54
- SWest
- 313 posts
element33
I've done some rigging in the past with Maya as well as Blender.
There are a couple of different tools in Houdini that can be used for joint orientations.
Orient Joints SOP basically for aligning one of the axis along the bone (it works). This is the quick and rough part.
Then Skeleton SOP for manual tweaking. There are some options such as numeric editing and snapping to 45 degrees. It works as well.
Finally I use some VEX (shared by the community) to orient selected joints to the world coordinates. This is used when the above is inefficient.
I've studied rigging and especially related things in Houdini for a couple of years now at a hobbyist level and would claim the above is enough to do the orient joints task without frustration.
Besides that there are a couple of additional tools that seem to work fine, for example the mirror joints node. It seems that it does not invert the scale.
SideFX also responded to an RFE request as well regarding this.
However, guessing what nodes are designed to do based on reading their names is probably just another way to waste your time.
- anon_user_09389530
- 205 posts
SWest
Hello, do you mean just rotating the joint manually or? Like with a child compensate etc, or is there other approach? thx
Also, is it possible for you to share the script to orient the joints to the world axis? thx
Edited by anon_user_09389530 - May 18, 2024 11:24:45
I contribute to the beauty of this world
https://houdininotes.ivanlarinin.com/ [houdininotes.ivanlarinin.com]
